open both hi and low needles just a tad. What have you got to loose? Mine we doing that and it kept acting like it was starving from low to high rpm when they would get good and warm/hot. Seemed like opening the low end was the answer, but the answer to mine was opening both needles a little. Brian
ORIGINAL: raptureboy
Yeh, I will dump the gas still and try that first, but when the cowls are on they both feel really warm all over, even on the spinner. I will take some pictures of my setup after work
and post them on here. The temp last evening when I was flying was in the mid 80's, not nearly as hot as early in the month closer to 100 deg then. Thanks, for all for your input, I'm sure it will be something simple i've overlooked.
