RCU Forums - View Single Post - 2 Stroke V. 4 Stroke
Old 08-18-2011 | 12:47 PM
  #32
opjose's Avatar
opjose
Default RE: 2 Stroke V. 4 Stroke
Start with a prop that has a more mass, like an APC prop. Also opt for a lower pitch ( so you can leave the engine at a slightly higher idle ) at first until it is run in.
Once you've run a gallon through the engine swap out the props and return. You should then get a nice idle around 1800 RPM.
