ORIGINAL: wjcalhoun
GSNut
You CAN make your 7C idle down - like the 8FG. Mix throttle to throttle, and put its activation on a switch. I flew 'idle down' on my 7C for a long time before I upgraded to the 8FG.
wjcalhoun
Thanks wjcalhoun !
Will get back to my 7 C asap. Just ordered new Sanyo's (2000mah) all the way around including the Tx's and double packs for the planes. Should be here about Monday or so, then b. pack building time. I don't trust my Old Walmart $ 1.00 per each nicad after 6 years of use. Some packs are starting to show flat cells.
Now just find a suitable IBEC ?
Cheers
