RE: OS 2 cycle problem question
Try pulling the high speed needle out and flushing the system, then clean the needle good before putting it back. Sometimes I flush with a full tank through the muffler ( pressure ) line all the way through the carb.. If you use this method be sure you clear the system so you don't have a fuel lock. ( pull the plug and turn it through or spin it with the starter ) just watch your eyes when you spin it through. ENJOY !!! RED
