Digital pressure gauge from Dreamworks question
OK,
Here is a question that will make me fill slightly silly once I get the answer. I have been working on my SkyMaster L39 for the last 2 weeks and it is near completion and I have burned a lot of brain cells doing the final rigging. I have one of the digital pressure gauges from Dreamworks and I cannot remember if it came with instructions or not. The biggest question I have is:
1) It came with 2 each Air Power Three way fill valves. The big question is where do the 3 nipples connect to? I can figure one to the gauge, one to the tank, and the third to the ??????
2) Second question is: To power it up, I know you need a male/male servo lead plugged into a spare channel or separate battery altogether (?). If to a batter it will obviously need a switch. I am using a 12X but my spare channels are slowly being used up.
Any help is appreciated.
