RCU Forums - View Single Post - Normal Dbm readings?
Old 08-19-2011 | 05:22 PM
Edgar Perez's Avatar
Edgar Perez
My Feedback: (13)
Default RE: Normal Dbm readings?
You can see that your Rx1 frames were very high and the dropped to 0. However this happened at the same time that your Tx frames dropped to from ~95 to 50.
Later your Tx frames when up back to 98, and at that same time, your Rx1 frames came back from 0 to 100.
I don't think your Rx1 frames really went to 0 at all. It seems to me your transmitter module did not receive the information from the receiver and that why it was showing 0, when in reality Rx1 was always very good (90-100).
Weatronic transmits a weaker signal from the receiver to the Tx, because it only uses one antenna for that. Typically this will happen to me for a few seconds. Yours lasted too long. Maybe antenna #1 is being blocked? Try changing its position.
I doubt your plane was at risk.
If you want more opinions, you should post in the other thread that I mentioned in my previous response. There are some good experts there.
Good luck
