RCU Forums - View Single Post - Jetcat kerosene conversion start problem, please help!!!
Old 08-20-2011 | 02:21 AM
Steve Moore's Avatar
Steve Moore
Default Jetcat kerosene conversion start problem, please help!!!
Hello everyone, I have converted a P200 gas start to kerosene start, I have changed the start setting on the ECU version 6 to kerostart as per the instructions, now, with a fresh 7.4v 2s lipo (5000mah) ( and correct battery setting on ECU) the engine will happily ignite every time, however the time between the initial ignition and main fuel feed is is so long that the ignition times out, however i have had 5 or 6 successful starts resulting in full running of the engine but far more failed starts (ignition time outs) I don't really want to change it back to gas start but if no one has any ideas to a solution I will not have a choice.
Is there a way of adjusting the time between ignition and main fuel feed?
Any advice would really help
