RE: Topflite Gold kit P-47
CAUTION ! For those of you who are going to use the fixed gear provided with the kit. Make sure the axle for the tire is forward enough as drawn on the plans. My metal wire was bent to where the wheel was straight down from the torque block makeing the wheel axle 1,1/2" to far back for proper tire location. I bent the wire to re=set it forward..By leaving it back as bent, you will cause a nose over problem when taxiing or landing also can cause earily lift off on take off causing a stall..... get a good look at your plans for proper angles... very important for good ground handleing.....good luck!
