RE: Digital pressure gauge from Dreamworks question
Hello George,
Good to hear from you buddy.
Thanks for the info on the fill valve, I was drawing a blank as to where the 3rd nipple would connect as this was the first time I have seen/used them. Todd from Dreamworks recommends using water traps with the EV-5 which is what I am using so I will have one nipple going to the twin retract tanks, one nipple to the inlet "A" on the air pressure gauge and will blank off the other nipple. I do not want to put the third nipple on the system since the water trap will be between the tanks and the EV-5 as designed (I think????). Same for the extra tank for the Brakes. It will have a separate water trap and 3 nipple fill valve going to inlet "B" of the pressure gauge and the third nipple will be blanked. See pic below.
v/r
Ken
