RCU Forums - View Single Post - Jetcat kerosene conversion start problem, please help!!!
Old 08-20-2011 | 10:54 AM
Vincent's Avatar
Vincent
My Feedback: (61)
Default RE: Jetcat kerosene conversion start problem, please help!!!
Steve,
I assumed your old fuel pump was starting and running perfect on propane?? if that is the case i find it hard to believe now its suddenly inop on kero start?? Make sure you do not have the fuel and gas start valves reversed on the jet when you did the conversion.Also if you are using the 3mm propane tubing replace it with 4mm for kero start.
Vin...
