camber setup
You can get an OK camber gauge from RPM. You stand it flat on the table and put is against a wheel without a tire on it to find the camber. It can also be used for toe. Just put is up against a wall.
I just had an idea! Cut a protractor in peices so they overlap enough to slide it back and forth. Attach them together at the bottom with a bolt and nut and volia!
