RE: OUTLAW from EXTREME FLIGHT
If I was home I could send you a pic. On the original we usually used non remote needle valves. if we use a newer motor with one we cut it off the backplate and lay it on top of the motor then you don't need the skid. Also on the original the rudder servo was in the body, on my ARF I mounted it across from the throttle servo just like the throttle servo is mounted. I also mounted my elevon servos so the arm exits the bottom like the original.
Start with the 8x6 and yes a mousse can will pick it up a bit or get a full pipe...
