RE: 12X auto dual Rudder rate?
Have you tried setting up a stick position switch on the throttle stick? Then using the SPS you can either use it to trigger the extra flight mode, if you are in ACRO or use it as a select switch for a program mix to modify the rudder rate.
Allan
