RCU Forums - View Single Post - Topflite Gold kit P-47
Old 08-21-2011 | 05:25 PM
  #311
Goran619
Default RE: Topflite Gold kit P-47
Well update on my jugs maiden flight, still hasn't happened. I brought it out to the field this afternoon, fueled it up did my preflight and went to fire it up..... Nothing happened turned it over about 5 more times and nothing. The guys I fly with were wanting to see it in the air so they convinced me to pull the cowl off and try and figure it out. So I did, found what we thought the fuel lines to be mixed up. Swapped the fuel lines on the carb and got it running but would stay running kept getting air bubbles in the fuel lines.
I said screw it and gave up on it for the night and went and flew my mustang. Almost had a mishap with that plane as well, brought the plane around for the final approach and as I turned left I lost orientation on her. flew it right along the tree line, I even think the right wing tip brushed the leaves...afterwards I had to go home and change my pants.....lol
Well I got home and dug into the jug and pulled out the fuel tank, I really don't know what was wrong. The only thing I can think of was when I had the fuel tank out last time I pulled a little to hard on the carb line as I was feeding the lines through the firewall. I ordered a few things for the fuel tank and lines to hopefully eliminate any problems, should be here before the weekend. Bad thing that happened though is that for some reason when fueling the tank over filled in the fuse and I got gas all in it. I cleaned it out as best as I could and now its drying out. Question though how tight do you tighten the fuel tank plug? I thought you tighten it until the plug just starts to push past the outter plate. Any help with this will be appreciated.
This was the 3rd time I've tried to maiden her and I have issues with the fuel system all 3 times, different problem each time. I'm starting to think this plane just doesn't want to be flown
Jordan
