RE: ofna jammin truggy questions
no conversion kit for truggy, only buggy.
but all you need to convert is spur, ring and pinion gears, chassis, tank, chassis braces, radio tray, front and rear center drive shafts.... everything else bolts on and are the same... might want to get the X2 center diff mount too, it works better, and eliminates the spacers.... i did the conversion right when the X2 CRT came out off ebay, and spent like 150 bucks. just was patient about it. but now you can buy a slightly used X2 for about 150 bucks. i sold mine for 200 i think about 2 years ago.
also if i remember right, on the diffs, the gears in the inside that cross, the X1 says one shim on each, on the X2 for some reason needs 2 on each gear. you can run 1 but the internal gears will strip after about 5 gallons. just something i learned running jammin.
