RCU Forums - View Single Post - Topflite Gold kit P-47
Old 08-22-2011 | 03:23 AM
  #314
twn's Avatar
twn
Default RE: Topflite Gold kit P-47
ORIGINAL: Goran619
Question though how tight do you tighten the fuel tank plug? I thought you tighten it until the plug just starts to push past the outter plate. Any help with this will be appreciated.
This was the 3rd time I've tried to maiden her and I have issues with the fuel system all 3 times, different problem each time. I'm starting to think this plane just doesn't want to be flown
Jordan
I usually tightened just about to the point of stripping, lol [X(]
I have started using water bottles n seal-all. I put the lines through as normal through the bottle cap with the rubber stopper and then once it is all workin the way I want I seal-all the bottle cap to the bottle (tighten of course too...) I also use the aluminum sulivan high pressure stopper setup... Lots of us are going this method now because the normal tanks leak n fail. Happened to me too...
A 500ml fiji water bottle gives my dle55 about 16-20 min of run time wide open. More than enough for a flight. I like the 500ml fiji bottle because it is rectangular in shape.
Plus with water bottles they are clear so u can see the fuel very easily.
With the aluminum stopper setup u gotta cut the outer lip off n grind it flat so it will sandwich n seal the stopper to the cap.
