RCU Forums - View Single Post - Stall servos?
Old 08-22-2011 | 07:11 AM
Nathan King's Avatar
Nathan King
Default RE: Stall servos?
A servo will stall when it encounters a load so great that it cannot move to the commanded position. Required torque > Avaliable torque. For example, if your endpoints are not adjusted properly and the pushrod binds your servo willstall.Stalled servos draw a lot of current (which can quickly drain a battery)and the motor/board inside the servo can be damaged.
