RCU Forums - View Single Post - Larger Revolver
Old 08-22-2011 | 10:09 AM
  #3622
iflywhenican
Default RE: Larger Revolver
You guys that are trying for a good and easy way to remove ca hinges...simply use a thin cutting wheel on a Dremel and cut right into the hinge. It will remove the material usually in one cut. If you choose to go with Robarts, then use Gorilla glue instead of epoxy for a better bond. Just make sure you wet the balsa before gluing.
