RCU Forums - View Single Post - BH T-28 Assembly
Old 08-23-2011 | 05:49 AM
  #918
Warbird Joe's Avatar
Warbird Joe
Default RE: BH T-28 Assembly
ORIGINAL: MX240
Ok Joe,
I will check the C/G next time he is out at the field as it sounds like it is not a common problem with this plane.
Jim
Jim that plane doesn't even need flaps to float in. Might want to check the balance on the wings as well. Pick the plane up and have one person hold the plane from the back and one from the prop and see if it tips left or right. It's just not a bad habit this plane has. As a matter if fact the plane has none from my experience or from the rest of the guys experience. Hope this helps.
Joe
