RCU Forums - View Single Post - OS-75 fuel problem
Old 08-23-2011 | 07:35 AM
LeeB1
Default RE: OS-75 fuel problem
Jim
Thanks for your response. Glow plug was replaced needle screw is fine no air bubbles OS75 AX engine. Crankshaft "looks/feels" fine but I also concluded that its a bent crankshaft. I don't have a dial indicator so its hard to tell. Ordered a new one this morning.
Although I have not looked at the piston rod I don't think a bend there would result in an after run fuel "dump". I think the bent shaft resulted in an air gap that allows fuel to be pressured past and out the venturi (its a side mounted engine).
Will update,
Lee
