OK New foam block ready to start rough shaping
Had a bad scare when I went to take the last picture. Camera would not power on. So after checking batteries and card I took a good look under the battery/card cover. Did not look right. Did not see a metal battery connection tap on the inside of the cover. Some looking and I found it on the floor, very slightly bent by my shoe I'm sure. Put it back in and a course it it not stay on its on.[&o] So I built up a little bead of super glue across the plastic pins that go through the middle of it (using a tooth pick to apply) and then set it with kicker also applied with a tooth pick.
HOT DOG, IT WORKS. I will keep an eye on it in case it needs a more secure repair.
