RCU Forums - View Single Post - Which servo on throttle
Old 08-23-2011 | 11:21 AM
Truckracer
My Feedback: (19)
Default RE: Which servo on throttle
ORIGINAL: spaceworm
Or, if the servo fails at WOT, then you are flying until the fuel runs out with no throttle control.[]
And .... you hope all the control surfaces and everything else stays attached to the plane during what will seem like hours waiting for the fuel to run out. Most lightweight 3D models are really not designed for extended periods at wide open throttle. Use a throttle servo of the same quality and speed as any other in the plane. Torque requirements are certainly far less.
