RE: SIMLA BUILD THREAD
Duane,
In the last photo of the wing, the servo lead appears to have a different means of "protection" at every other rib and then noneat the ribs that are open. Can you explain a little more about what you used to dothis? I am a little hesitant to add yet another tube to run the servo wire through. Also the servo hatch mounts appear to be four blocks instead of the two suggested in the kit. I did determine that in order to install my servos inside the wing, I was going to have to notch both sides of the two mount arrangement, essentiallyleaving a four block arrangement. I realize that this is a small point, but I was just curious.
