RCU Forums - View Single Post - Which servo on throttle
Old 08-24-2011 | 09:06 AM
Truckracer
My Feedback: (19)
Default RE: Which servo on throttle
ORIGINAL: Ernie Misner
Can anyone tell me why this is called ''optical''....... Optical Kill Switch ? I know that the transmitter can can control it, but why the optical term.
Thanks loads,
Ernie Misner
Here, this should help explain the optical part of these devices.
http://en.wikipedia.org/wiki/Opto-isolator
There are two types of optical kill switches in common use for gas engines. In the first type, all the electronics are contained on one board so the isolation is only the small distance that can be had on that board. In another type ... made by Smart-Fly, they actually use a piece of optical fiber between two separate boards so the only connection between the receiver and the ignition is the length of fiber. This is true isolation in my opinion. Single board units can never offer this degree of isolation.
