RCU Forums - View Single Post - SIMLA BUILD THREAD
Old 08-24-2011 | 10:21 AM
  #265
billberry189
Default RE: SIMLA BUILD THREAD
ORIGINAL: billberry189
Richard,
I hate to be the bearer of bad news, but cracking is not good. Usually it comes from applying too many coats too fast. The best way to eliminate the problem is to sand the cracks completely out and reprime. Thats not the only way, but it is by far the best way. I'm sorry about that! I suppose the best advice that I can give you is to lighten up on the heavy coats. Light to medium coats while letting each coat flash off before the next coat should give you satisfactory results. Just don't give up. Keep trying and you will get it. If it makes you feel any better, my first paint job ran off on to the floor.
Well, I have run into another problem. It seems that the more I get done on the Simla the less room I have for indoor photos. Holy Cow this thing is big!
ID:	1653015   Click image for larger version
ID:	1653016   Click image for larger version
ID:	1653017   Click image for larger version
ID:	1653018   Click image for larger version
ID:	1653019   Click image for larger version
ID:	1653020   Click image for larger version
ID:	1653021   Click image for larger version
