ORIGINAL: crhammond
We're getting alittle off track but 32:1 in my DA 100 makes a GIGANTIC difference in power. Lots more mess but if you wax the plane it wipes off easy.
I like CH ignitions. They cost a little more than the cheap ones but they are proven rock solid. I had 3 $175 DA ignitions fail on me this summer. Not good. One cost me a very expensive 40%er (admittedly some pilot error and bad luck was also involved.) The others just resulted in reminding me I need to work out and eat right after my heart got going (both were greaser landings.)
I had a lot of troubles learning my YS170 this season. I kinda got the hang of it after 300 flights or so but even with a delay start glow driver I had a lot of kickbacks. When it works its like a swiss watch with GOBS of horsepower.
On my Comp-Arf Integral I am using a 2300 A123 and a heavy Aluminum spinner and I could still (just) make FAI weight with an ignition system (I might need a lighter spinner and to look to save and ounce or two here and there.) But I am still some years away from flying FAI. I will fly Masters for next season but I will mostly be flying Pattern just for the practice since it is the hardest thing. I find it makes my IMAC flying seem not so difficult. An ignition Alky system should make a fantastic setup for a 2M plane that I can fly every day (keep it in the car and stop by the field for an hour whenever I can.)
You might consider using Ed Alt's IBEC. You can run on just the airborne battery pack with the IBEC. If you are using a separate 2300ma 123, you will save the weight of the bat and switch for a cost of 17 grams (and $55). Turn the CDI on-off from your TX. Safer than "normal" set-ups too
