RCU Forums - View Single Post - ideas for sealing covering seams
Old 08-24-2011 | 08:28 PM
91zulu
Default RE: ideas for sealing covering seams
ORIGINAL: speedracerntrixie
I like Minn's idea, The nailpolish idea has 2 things working against it. One, the covering by nature will not accept paints. Ultracote will after some scuffing but hadhision is not ideal. Two Nailpolish is not fuel proof. IMO you would be better off keeping a coat of wax on the airplane thus providing a barrier so fuel can't get to the seam. I actually have never had an issue with seams coming up provided they were put down correctly in the first place. Keeping things clean during the covering process helps this greatly.
You must either fly electric or have hanger queens because every plane I had that was covered in plastic eventually peeled up especially the side of the exhaust. You need to fly a lot more, stop being scared.
