RE: SUMMIT HELP
I would check your manual to see what the green and red lights mean. There are several different readings depending on how fast they are flashing. If you don't have a manual you can find this info out from Traxxas's website. Anyways, it sounds like your receiver isn't linked to your transmitter, which I assume you have a 2.4ghz with a new Mini Summit. Also your ESC could need reprogrammed, which you would need to go through the steps to do that. Just make sure you have a charged battery when resetting everything. I would start with the receiver first, if it isn't linked then it's not getting any signals at all.
