RCU Forums - View Single Post - P80 SE Problem
Old 08-26-2011 | 12:51 AM
Alireza-m
Default P80 SE Problem
Dear All,
I have a Jetcat P80 SE ,ECU Ver is 6.1 , I change the start to Kerosine start before I run the turbine for first time Du to manual proceed I start to change the start sequence to Kerosine start but there is no acceleration on GSU I tried it several time but nothing happened .
I push both ignition and + bottom then turn on the RX but nothing happened , then I hold ignition and - bottom ,then I saw on GSU the propane start actived ,but I never success to active kerosine start .
it is not first time I changed the jetcat to k start but I dont know what is the problem this time .
Please advise me.
Thank you!
