RCU Forums - View Single Post - super tigre.10 install problem
Old 08-26-2011 | 06:44 AM
elgerythms
Default super tigre.10 install problem
just installed my new super tigre.10 brushless outrunner, into my fairly new AT yak 54. running stock ESC 20A and stock prop which I drilled out, I believe it's 11x4.7...It worked fine two times in the house all the way up to full throttle, and when I got to the field, it would just glitch, I could almost start the prop by hand and slowly roll on throttle but it wouldn't get to full power, and it just got worse and worse. Now it won't go at all just glitches and bounces back and forth with any amount of throttle applied. the yak came with a bind plug, could my radio somehow have lost signal? if so I have no idea how to bind it, and if not that, then where else do I start looking for a problem? I think I am going to get rid of my plug connectors, maybe get a little better quality ones might help, otherwise I am lost. any help would be appreciated. thanks for reading.
Elger
