RCU Forums - View Single Post - Tuning Problem
Old 08-26-2011 | 11:55 AM
Antique's Avatar
Antique
Default RE: Tuning Problem
Not grounding the ignition will kill the hall sensor, the spark can be seen jumping the gap between the magnet and sensor...20K volts is a little high for the sensor,,,,
The plug wire has a braid around it to be connected to ground..Either the steel cap or the cylinder....
