RE: Pattern weight rule - why?
I do not think I'm mistaken in everything I said, the size and weight limit, is that,a limit, if some of you do not "agree" with FAI, fine. F3A should be that, F3A, do a separate nationals and do not mix in ANY way AMA with FAI, otherwise nothing will change, F3A drives pattern equipment in the world and manufacturers, but AMA can keep it the way most people in the US want, everybody will be happy then.
I really do not expect any AMA class pilot to agree with me at all.
BTW I was Colombo's caller on the semi finals and I never saw a weight check done, so why is everybody still winning about that? AMA pleased pilots by not doing that, I don't know if it was done at the finals..
Regards
Alejandro P.
