RE: Taller gear for Apprentice?
I put 3.5 inch light weightfoam wheels on all three landing gear, mains and nose gear. Following ideas on the forum from an earlier post, I made a new nose gear out of 5/32" stock. The 5/32" nose gear is available from Du-bro and it only takes a slight bend outward and a bend upward on the axle part of the gear in order to put the nose wheel directly under the vertical shaft and steering attachments. The airframe sits up nicely and with a lot of prop clearance. I currently have installed a 11 X 7 electric thin prop and there is lots of clearance.
I have also changed out the 15 motor that came with the Apprentice for a Power 15 - puts out more power - but I remind myself there is no need to run a full throttle save special needs (such as a fun vertical departure).
The Apprentice looks like a bush plane and I am of a mind to call it the "Super Apprentice"
Seriously, the 3/52" stock nose gear by Du-bro requires a little bit of adjustment to fit and function, but it serves the purpose of mostly solving the tall grass problem. The stronger motor should also help pull it through and upout of the tall grass. The three and a half inch wheels fit on the stock main gear perfectly. Mike.
