RE: brushcutter engines
Typically, these engines are converted using the flywheel end as the output shaft as most flywheel ends of trimmers/brushcutters turn counterclockwise.
The threads on the flywheel end of the crankshaft is usually 8mm
You need a carb with both a high speed and a low speed mixture adjustment. Often a larger carb is used from what was on the original engine.
The mixture adjustment is for the prop load on the engine and not for altitude adjustment as these carbs all have altitude compensators.
Blower engines often turn the opposite direction so they have to be reversed or use the opposite end of the engine in some cases.
Stihl trimmer/brushcutters
<table cellspacing="1" cellpadding="3" border="0" width="641"> <tbody> <tr class="footertext"> <th bgcolor="#ffb060" width="12%"> <p class="footertext">MODEL</p> </th> <th bgcolor="#ffb060" width="22%"> <p class="footertext">DISPLACEMENT</p> </th> <th bgcolor="#ffb060" width="22%"> <p class="footertext">ENGINE POWER</p> </th> <th bgcolor="#ffb060" style="width: 22%;"> <p class="footertext">WEIGHT (LBS.)</p> </th> <th bgcolor="#ffb060" width="22%"> <p class="footertext">FUEL CAPACITY</p> </th> </tr> <tr bgcolor="#ffb060"> <td align="center" colspan="5" class="bold">Occasional Use Trimmers</td> </tr> <tr bgcolor="#cccccc"> <td class="footertext"> <p class="footertext">FS 40 C-E</p> </td> <td class="footertext"> <p class="footertext">27.2 cc (1.66 cu. in.)</p> </td> <td> <p class="footertext">0.7 kW (0.9 bhp)</p> </td> <td style="width: 19%;"> <p class="footertext">4.5 kg (9.9 lbs.)</p> </td> <td> <p class="footertext">340 cc (11.5 oz.)</p> </td> </tr> <tr> <td class="footertext">FS 45</td> <td class="footertext">27.2 cc (1.66 cu. in.)</td> <td class="footertext">0.75 kW (1.01 bhp)</td> <td class="footertext" style="width: 19%;">4.1 kg (9.0 lbs.)</td> <td class="footertext">330 cc (11.2 oz.)</td> </tr> <tr> <td bgcolor="#cccccc" class="footertext"> <p class="footertext">FS 46</p> </td> <td bgcolor="#cccccc" class="footertext"> <p class="footertext">27.2 cc (1.66 cu. in.)</p> </td> <td bgcolor="#cccccc"> <p class="footertext">0.75 kW (1.01 bhp)</p> </td> <td bgcolor="#cccccc" class="footertext" style="width: 19%;"> <p class="footertext">4.2 kg (9.3 lbs.)</p> </td> <td bgcolor="#cccccc" class="footertext"> <p class="footertext">330 cc (11.2 oz.)</p> </td> </tr> <tr> <td class="footertext"> <p class="footertext">FS 55 R</p> </td> <td class="footertext"> <p class="footertext">27.2 cc (1.66 cu. in.)</p> </td> <td class="footertext">0.75 kW (1.01 bhp)</td> <td class="footertext" style="width: 19%;">4.8 kg (10.6 lbs.)</td> <td class="footertext">330 cc (11.2 oz.)</td> </tr> <tr> <td bgcolor="#cccccc" class="footertext"> <p class="footertext">FS 56 C-E</p> </td> <td bgcolor="#cccccc" class="footertext"> <p class="footertext">27.2 cc (1.66 cu. in.)</p> </td> <td bgcolor="#cccccc" class="footertext"> <p class="footertext">0.8 kW (1.1 bhp)</p> </td> <td bgcolor="#cccccc" class="footertext" style="width: 19%;"> <p class="footertext">5.2 kg (11.5 lbs.)</p> </td> <td bgcolor="#cccccc" class="footertext"> <p class="footertext">340 cc (11.5 oz.)</p> </td> </tr> <tr class="footertext"> <td class="footertext">FS 56 RC-E</td> <td class="footertext">27.2 cc (1.66 cu. in.)</td> <td class="footertext">0.8 kW (1.1 bhp)</td> <td class="footertext" style="width: 19%;">4.8 kg (10.6 lbs.)</td> <td class="footertext">340 cc (11.5 oz.)</td> </tr> <tr bgcolor="#cccccc" class="footertext"> <td class="footertext">FSE 60</td> <td class="footertext">120 volt (60 Hz)</td> <td class="footertext">600 Watts (5.3 amps)</td> <td class="footertext" style="width: 19%;">4.0 kg (8.8 lbs.)</td> <td>-</td> </tr> <tr bgcolor="#ffb060"> <td align="center" valign="top" colspan="5" class="bold">Professional Use Trimmers & Brushcutters</td> </tr> <tr> <td bgcolor="#cccccc"> <p class="footertext">FS 70 RC-E</p> </td> <td bgcolor="#cccccc"> <p class="footertext">27.2 cc (1.66 cu. in.)</p> </td> <td bgcolor="#cccccc"> <p class="footertext">0.9 kW (1.2 bhp)</p> </td> <td bgcolor="#cccccc" style="width: 19%;">
<span class="footertext">4.8 kg (10.6 lbs.)</span></p> </td> <td bgcolor="#cccccc"> <p class="footertext">340 cc (11.5 oz.)</p> </td> </tr> <tr> <td> <p class="footertext">FS 90 R</p> </td> <td> <p class="footertext">28.4 cc (1.73 cu. in.)</p> </td> <td> <p class="footertext">0.95 kW (1.27 bhp)</p> </td> <td style="width: 19%;">
<span class="footertext"> 5.3 kg (11.7 lbs.)</span></p> </td> <td> <p class="footertext">530 cc (18.0 oz.)</p> </td> </tr> <tr bgcolor="#cccccc"> <td class="footertext">FS 90</td> <td class="footertext">28.4 cc (1.73 cu. in)</td> <td><span class="footertext">0.95 kW (1.27 bhp)</span></td> <td style="width: 19%;"><span class="footertext">5.5 kg (12.1 lbs.) </span></td> <td><span class="footertext">530 cc (18.0 oz.)</span></td> </tr> <tr> <td> <p class="footertext">FS 100 RX</p> </td> <td> <p class="footertext">31.4 cc (1.9 cu. in.)</p> </td> <td> <p class="footertext">1.05 kW (1.4 bhp)</p> </td> <td style="width: 19%;"> <p class="footertext">4.9 kg (10.8 lbs.)</p> </td> <td> <p class="footertext">530 cc (18.0 oz.)</p> </td> </tr> <tr bgcolor="#cccccc"> <td> <p class="footertext">FS 110 R</p> </td> <td> <p class="footertext">31.4 cc (1.9 cu. in.)</p> </td> <td> <p class="footertext">1.05 kW (1.4 bhp)</p> </td> <td style="width: 19%;"><span class="footertext"> 5.5 kg (12.1 lbs.) </span></td> <td> <p class="footertext">530 cc (18.0 oz.)</p> </td> </tr> <tr> <td class="footertext">FS 110</td> <td><span class="footertext">31.4 cc (1.9 cu. in.)</span></td> <td><span class="footertext">1.05 kW (1.4 bhp)</span></td> <td style="width: 19%;">
<span class="footertext"> 5.8 kg (12.8 lbs.)</span></p> </td> <td><span class="footertext">530 cc (18.0 oz.)</span></td> </tr> <tr> <td bgcolor="#cccccc"> <p class="footertext">FS 130 R</p> </td> <td bgcolor="#cccccc"> <p class="footertext">36.3 cc (2.2 cu. in.)</p> </td> <td bgcolor="#cccccc"> <p class="footertext">1.4 kW (1.9 bhp)</p> </td> <td bgcolor="#cccccc" style="width: 19%;">
<span class="footertext">5.6 kg (12.3 lbs.)</span></p> </td> <td bgcolor="#cccccc"> <p class="footertext">530 cc (18.0 oz.)</p> </td> </tr> <tr> <td><strong class="footertext">FS 130[/b]</td> <td><span class="footertext">36.3 cc (2.2 cu. in.)</span></td> <td><span class="footertext">1.4 kW (1.9 bhp)</span></td> <td style="width: 19%;"><span class="footertext">5.9 kg (13.0 lbs.) </span></td> <td><span class="footertext">530 cc (18.0 oz.)</span></td> </tr> <tr> <td bgcolor="#cccccc"> <p class="footertext">FS 250 R</p> </td> <td bgcolor="#cccccc"> <p class="footertext">40.2 cc (2.45 cu. in.)</p> </td> <td bgcolor="#cccccc"> <p class="footertext">1.6 kW (2.15 bhp)</p> </td> <td bgcolor="#cccccc" style="width: 19%;">
<span class="footertext"> 6.0 kg (13.2 lbs.) </span></p> </td> <td bgcolor="#cccccc"> <p class="footertext">640 cc (21.6 oz.)</p> </td> </tr> <tr> <td><span class="footertext">FS 250</span></td> <td><span class="footertext">40.2 cc (2.45 cu. in.)</span></td> <td><span class="footertext">1.6 kW (2.15 bhp)</span></td> <td style="width: 19%;"><span class="footertext"> 6.3 kg (13.9 lbs.)</span></td> <td><span class="footertext">640 cc (21.6 oz.)</span></td> </tr> <tr> <td bgcolor="#cccccc"> <p class="footertext">FS 310</p> </td> <td bgcolor="#cccccc"> <p class="footertext">36.3 cc (2.2 cu. in.)</p> </td> <td bgcolor="#cccccc"> <p class="footertext">1.4 kW (1.9 bhp)</p> </td> <td bgcolor="#cccccc">
<span class="footertext"> 7.2 kg (15.9 lbs.) </span></p> </td> <td bgcolor="#cccccc"> <p class="footertext">710 cc (24.0 oz.)</p> </td> </tr> <tr bgcolor="#ffb060"> <td align="center" valign="top" colspan="5" class="bold">Forestry Brushcutters & Clearing Saws</td> </tr> <tr> <td><span class="footertext">FS 360 C-E</span></td> <td><span class="footertext">37.7 cc (2.3 cu. in.)</span></td> <td><span class="footertext">1.7 kW (2.3 bhp)</span></td> <td style="width: 19%;"><span class="footertext">8.5 kg (18.7 lbs.)</span></td> <td><span class="footertext">750 cc (25.4 oz.)</span></td> </tr> <tr> <td> <p class="footertext">FS 460 C-EM</p> </td> <td> <p class="footertext">45.6 cc (2.8 cu. in.)</p> </td> <td> <p class="footertext">2.2 kW (3.0 bhp)</p> </td> <td><span class="footertext">8.5 kg (18.7 lbs.)</span></td> <td> <p class="footertext">750 cc (25.4 oz.)</p> </td> </tr> <tr> <td bgcolor="#cccccc"> <p class="footertext">FS 550</p> </td> <td bgcolor="#cccccc"> <p class="footertext">56.5 cc (3.45 cu. in.)</p> </td> <td bgcolor="#cccccc"> <p class="footertext">2.8 kW (3.75 bhp)</p> </td> <td bgcolor="#cccccc" style="width: 19%;"> <p class="footertext">10.0 kg (22.0 lbs.)</p> </td> <td bgcolor="#cccccc"> <p class="footertext">755 cc (25.5 oz.)</p> </td> </tr> </tbody></table>
