Launch problems - 1/2 A
Jeff has covered most of the ground on this one but what prop are you using? Torque REACTION is the issue,, and the larger the prop, the more reaction you'll get in response to the greater drag and inertia of a larger prop. Adequate dihedral helps. If all else fails, launch it with a pronounced bank to the right but then again, it could also be that you're not getting up enough airspeed on the launch.
