RCU Forums - View Single Post - Launch problems - 1/2 A
Old 08-19-2003 | 08:05 PM
William Robison
Default Launch problems - 1/2 A
Andy is right.
If the plane flies well after it gets airspeed, anything you do to correct a launching problem will lead to in-flight problems.
Just launch it in a pronounced right bank.
I've had some that took around 45 degrees for a good launch.
One more thing, with a banked launch you also have to toss the plane upward instead of level. Again, experiment for amount. Usually about ten degrees up is fine.
Bill.
