RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 08-29-2011 | 07:18 AM
  #4434
SpinnerRow's Avatar
SpinnerRow
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: microdon2
will185 \ SpinnerRow - I've noticed the same thing with this DLE 20 - I can't seem to kill it with the throttle control alone. And I've also confirmed that the throttle plate is seating correctly. Must be some other air\fuel leak in there? Does anyone know if this carb is designed this way? Seems odd. But, as Spinnerrow states, I use an Opti-kill swtch or a servo-controlled choke to kill it (depending on the plane). Haven't tried to kill my DLE 30 with throttle control yet - will have to test that next time out.
There is a small hole in the throttle blade. This little motor idles low enough that it might be getting enough air to idle if you have a heavy prop like an APC on it. Some people put silicone over that hole so that the engine will choke faster but I've left my two DLE 20s alone and use an optikill.
