RCU Forums - View Single Post - SD-10G & RX700 Range Check
Old 08-29-2011 | 11:21 AM
Nathan King's Avatar
Nathan King
Default RE: SD-10G & RX700 Range Check
ORIGINAL: mschulz531
Where did you buy the radio?
Good thing you found this during a range check instead of in the air!
<br type="_moz" />
<span style="font-size: x-small"><span style="font-family: Arial">I purchased it at a local HobbyTown USA store. I am very careful with my set up because I have a considerable investment in my pattern model and because I'm a perfectionist. What I don't understand, though, is if my range issue is related to the recall. The recalls simply states "momentary loss of signal when using the SD-10G in FHSS-1 modulation
typically in crowded environments." My environment was not crowded, and it's a range issue - not intermittent signal loss.</span></span>
