RE: Re-Engineering A Dumas Pay'N Pak
No Yota, you're not even close. Rule number one is to remember the capabilities of your equipment and work within those capabilities, not outside of them. This applies to mills, lathes, saws, sanders, drills and any other tool you may use to complete a task. Would you use a 1/4" drive ratchet to break loose a 1" torqued down bolt?
