RE: Fokker DRI Build Along
Well, I really don't want to find out,,,if you know what I mean. [X(]
I can still remove more weight up front by way of battery size. I will search for CG and play with it some.
I also don't like how the wing is held on in the middle. The cabines? were just screwed into wood with allen head 8/32 screws. Aaarrrrgggg. I replaced them with 10/24 as the wood threads were stripped out...You think...? Eventually I plan to epoxy the screws in place but not screw them in all of the way and cut off the heads. I can then leave them in and put some nuts on instead. I really don't want to remove/replace the covering to access these and make it stronger.
Rick
