RE: butterfly vent hole ???
The butterfly is not positioned correctly on the throttle shaft..The edges are beveled to completely close...The impression on the valve is there to line up the valve correctly in the venturi...loosen the screw and rotate the valve until the dent on the other side touches the shaft....Loctite the screw when you put it back...
