G.P. Pitts L- brackets
OK, thanks.
I have the updated version and the brackets have a good radius. However, the ones that go on the tail are formed according to the instructions, but incorrect as far as good aircraft practice. Example, on the horizonal stab the bracket is installed such that it loops back over itself. Under load this bracket would attempt to turn around by itself. I realize these are for looks only. If this is the case they should be installed correctly. I straightened mine out and reformed them to the correct angle. Look at any 1:1 at how they are installed for verification.
Dan
