ORIGINAL: JohnBuckner
Shift some foam around, a hobby knife, Razor saw, Chainsaw or Class 1 explosives fix the problem,
Heh...
On most of the ARF's I've dealt with, the support/formers holding the tank in place are not easy to cut nor get to without performing rather extensive surgery on the plane.
Nor can you shift things around using foam, etc. as often the tank bung is designed to go through the firewall hole.
A chainsaw or explosives may work, but that may be beyond the scope of a beginner's forum.
