RE: Help from TOM
The pressure under the diaphragm is slightly below atomspheric pressure controlled by the spring forcethat closes the needle valve. Tank level within our size limits will have no effect on the tuning, now connected to a 20' diameter tank and you just might need to readjust as the level changes.
