RCU Forums - View Single Post - Digimix useful device
Old 08-31-2011 | 01:26 PM
ticketec
Default RE: Digimix useful device
ORIGINAL: invertmast
Here is a question.
can it take an input from one channel, but operate just One servo when the stick is moved in one direction, and then a separate servo when the stick is moved in the opposite direction? And be able to turn both of these servo's off with the input of a separate channel?
For example.
when switch A is in position 1:
A roll to the left is input by the transmitter. servo #1 moves to extend a spoiler, but the servo #2 does not move.
A roll to the right is input by the transmitter. servo #2 moves to extend a spoiler, but servo #1 does not move.
Then with switch A in position 2: Neither servo #1 or #2 move.
Can it do that?
Invermast,
I have a mix almost exactly as you have descibed above programmed in on my JR 9X. I use it so I can have differential thrust from my PBY Catalina for taxing on the water, so any radio above a 9xII should do it easily.
dave
