RCU Forums - View Single Post - Help from TOM
Old 08-31-2011 | 03:23 PM
  #36
captinjohn
Default RE: Help from TOM
ORIGINAL: Tired Old Man
That's one of the things about our engines that make them such a pleasure. Tank location has zero impact on engine performance when kept within a rather wide range of allowable locations. Essentially if the tank can be installed anywhere in or on the lane the engine will function the same.
A non-pumped glow engine will experience gravity feed performance issues but that is very difficult to develop in our planes. I've seen a lot of vent tube installations that generated numerous problems. Never install a vent tube unless first determining there is absolutely a need. An improperly installed, restricted, or excessively long vent tube delays or alters the pressure sensed by a diaphragm until long after the aircraft has passed the point the engine needed the information. For a period of time there was, and likely still is, a lot of people that were automatically installing a vent tube when they installed an engine. Somewhere, someone said a vent tube eliminated a mid range burbal. That same person probably forgot to let people know they could also cause one, along with a few other irritating issues.
I will admit I did intsall the vent line just in case....so I will just slip the line off it.The line was about 7-9 inches long! If that works....Thats great. Thanks, Capt,n
