RCU Forums - View Single Post - You Can Do Engine Problems
Old 08-31-2011 | 06:26 PM
Live Wire's Avatar
Live Wire
Default RE: You Can Do Engine Problems
Food for thought! A 2 St engine inverted can not hydro lock unless you are trying to start it or it has been run rich and let set! The carb. points down and fuel will not run up into the crank. A 4 St. will because the carb points Up and the fuel fills the valve port and into the cylinder.
Larry K
