RE: Help Identifying pattern model
Tom,
forget about it, you won't find any Curare pictures that look anything like your model. Often, people unfamiliar with classics see there is an anhedral stab, a tuned pipe and retracts and automatically say it's a Curare - probably because they don't know any other classic pattern models.
I could probably run off at least 10 different aspects of your model after looking at the pics for 10 seconds that don't conform with Hanno's design - it's not a Curare.
What it is I'm not sure but I strongly suspect it is an American or English design and original kit - unless it is a one off done by someone which is unlikely if it has a glass fuse. The swept back wing is a key aspect of the design as is that canopy which has a high point much further back than the vast majority of classics during the late 70's and 80's. I have the feeling it is a mid-70's design given the shape of the vertical and the upright engine configuration but the concealed pipe under the fuse dates it a little later. It is also possible that it was an earlier vintage kit which was built many years later with a few variations on the original design concept (e.g., the concealed pipe).
BTW, to answer you last question, yes, there is a larger sibling to the Curare called the Super Curare but it is very similar in design to the original - there are only few pictures of SC's on the net.
David.
