RCU Forums - View Single Post - OS BGX-1 Glow to Gas Conversion (Yeah!) Thanks Max
Old 09-01-2011 | 07:37 AM
rcnats's Avatar
rcnats
My Feedback: (56)
Default RE: OS BGX-1 Glow to Gas Conversion (Yeah!) Thanks Max
The conversion process is VERY EASY!!! There are less than 12 steps to do it. The "hardest part" was drilling a tapping the 1/8 pressure fitting. I had the honor of being the 1st one to do this in the USA! . Thanks Max. I had to add some flat washers to my pressure fitting as I used the crankcase mount which is thinner than the regular back plate. I informed Max and he's making the necessary adjustments . Having the timing ring preset was also a plus. From start to finish takes less than 30 minutes. After choking the carb and 3 flips it was ready. 2 flips later and it running! Tuning the carb was an adventure, but after reading some posts here on RCU it was easy as well. As you can see in the pics I got it pretty close to where I want it to be. This was my first glow to gas conversion and the conversion kit from Max is awesome. I plan to put this engine in my Team Duster 1/6 Air Tractor A502-B . Thanks Max!
