RCU Forums - View Single Post - Composite Arf paints.
Old 09-01-2011 | 03:24 PM
luv2flyrc's Avatar
luv2flyrc
Default RE: Composite Arf paints.
ORIGINAL: AKB
Does anyone know if the paints that Composite Arf supply for touch up, are PPG Concept paint?
Alan
It's definitely not PPG Concept. Not really sure what it is but, it seems to be a 2 part urethane, at least I was able to reduce it with a urethane reducer but, it doesn't adhere like an auto paint. I found that when I tried to buff it to match the shine, it was easily pulled from the surface or would "crinkle". I understand that it's the same paint that they use "in the mold" and it's really not intended as an external paint.
Anyway, it's not bad for doing very small touch ups but, for larger areas or where blending is required, you'll be happier with an auto urethane.
Mike
